RCU Forums
-   O.S. Engines Support (https://www.rcuniverse.com/forum/o-s-engines-support-133/)
-   -   O.S. .46fx (https://www.rcuniverse.com/forum/o-s-engines-support-133/1065850-o-s-46fx.html)
mkent78 08-18-2003 01:02 PM
O.S. .46fx
I recently purchased a SIG something extra ARF for my second plane. I plan on using my .46FX. I was wondering what prop I should use? What preformance characteristics differ from an increase in pitch/diameter? I currently have a 10X7 on it for my trainer.
Any thoughts? Also, any comments/suggestions on this plane will be greatly appreciated.
:D
Jim C. 08-18-2003 01:09 PM
O.S. .46fx
if you run an 11x5 you will have good vertical but less speed, if you run around 11x8, you plane will haul ***. keep it in the 11 inch range.. 10 may be a little short for it.
mkent78 08-18-2003 01:26 PM
O.S. .46fx
What happens if I use a prop that is too short like a 10X7 (which i have on the motor now)? I have to use a 10in for my trainer due to ground clearance.
Jim C. 08-18-2003 02:17 PM
O.S. .46fx
if its too short, you could overheat the motor and then its junk
Bax 08-18-2003 03:36 PM
O.S. .46fx
On the O.S. Max .46 FX, we regularly run APC 10 x 7 props. This won't hurt your engine at all. A lot of people run 10 x 6 props, but that's a tad small, but the engine will still handle it.
Overheating would be caused by too much propeller, a fuel with a too-low oil content, bad cooling, and bad needle adjustment.
With good fuel, you should have no problems with a 10 X 7 prop on your model. Just make sure it gets plenty of cooling air and you're using a good fuel.
