RCU Forums
-   O.S. Engines Support (https://www.rcuniverse.com/forum/o-s-engines-support-133/)
-   -   Os 25 fx max head torque problem (https://www.rcuniverse.com/forum/o-s-engines-support-133/11669099-os-25-fx-max-head-torque-problem.html)
pjacko 09-03-2019 08:16 AM
OS 25 FX MAX head torque problem. When I tighten the head screws down the piston gets so tight near top center I can't rotate the crankshaft. The notch in the sleeve matches the pin in the cyl. I even took the shim off the top of the sleeve and the crank shaft is littel looser but still to tight. I APPRECIATE ANY HELP WITH THIS. THANKS
