OS .61 SF (Ring)
Finally finished the plane I bought this engine for 8 years ago (don't ask).
I seem to have misplaced the manual for this engine and cannot locate one on the OS site. How can I get an electronic copy? Can you advise me of the proper break in proceedure? I think the carb is the 7M type. What is the procedure for setting the carb? Should I use 100% synthetic or is a syn / castor blend OK? Thanks, RJ |
RE: OS .61 SF (Ring)
Please send an email to the address below, and we'll be able to send you instructions for your engine. It will contain all the info you'll need to run your engine.
| All times are GMT -8. The time now is 10:29 PM. |
