RCU Forums
-   O.S. Engines Support (https://www.rcuniverse.com/forum/o-s-engines-support-133/)
-   -   Question on OS40C Carb (https://www.rcuniverse.com/forum/o-s-engines-support-133/2318471-question-os40c-carb.html)
capman231 11-04-2004 09:58 PM
Can any one tell me if the OS40C is a spray bar type carb
Capman231
Bax 11-05-2004 10:52 AM
RE: Question on OS40C Carb
The O.S. Max #40C carburetor for the .46 FX-H engine does have a spraybar. The high-speed needle is on one side of the carb and the idle mixture adjustment is on the other side, in the center of the throttle arm.
capman231 11-05-2004 04:55 PM
Thanks Bill
I knew you knew the answer or at least could get it if you didn't...
Thanks Again
Capman231
