OS91FX RECOMMENDED PROPPELLER
hI
i AM fROM of Colombia , and i have purshased a 91fx with the header and the tuned pipe. Whe fly at 2600 metters , what proppeller do you recomend my??? thanks for help Sergio... |
RE: OS91FX RECOMMENDED PROPPELLER
You may wish to run the engine with a lighter load than we would run here. Try an APC 14 x 8, maybe an APC 13 x 8. The engine will handle running up to the high 11,000's in RPM, so if you have the engine running well, any propeller that will let the airplane fly well is correct.
