| petembx5 |
10-28-2005 11:41 AM |
.30 engine mount
I was hoping you might be able to help I want to mout an os .30 in my mugen truggy. I have the os .30 with the roto start back plate. The problem i am have is that you cannot use the stock engine mount because the backplate for the roto start gets in the way and it is not high enough. So basically it needs to be a bit higher and fit the engine. Do you know of any mounts that might fit. I know must people do not put a roto start in this type of truck and thats the problem.
