Pump for 46VXDF
Bax,
What would be a good pump to use for the 46VXDF. I was looking at a Perry ocillating pump, Perry pump regulator, or the OS PD04 PA104. Which one will work and is recomended. Thanks! Happy New Year! Andrew |
RE: Pump for 46VXDF
The O.S. pumpunit is intended to be used with the O.S. Max Type 46 carburetor. The two were intended to be used together.
We've not used the other pumps, so have no comments abou them. We don't know if the Perry Micro Oscillating pump can deliver enough fuel for your engine. You'd have to check the makers of the pump. |
RE: Pump for 46VXDF
Bax,
I will check that out. Thank you!. Andrew |
| All times are GMT -8. The time now is 05:11 PM. |
