walbro carbs?
hello bill...curious on the availability of a walbro pumped carb replacement for the os 160fx.
thanks much tony covino [email protected] |
RE: walbro carbs?
We have no knowledge of a Walbro carburetor installation on the O.S. Max 1.60 FX engine. Walbro carburetors are usually intended for gasoline operation, and the 1.60 FX is for glow.
RE: walbro carbs?
thanks for your reply. i am aware of the walbro carb on gas; however, i have seen a mvvs glow with optional walbro-pumped carb. your opinion...if walbro had a carb that would fit and met the carb criteria, would it perfom better than a pumped glow with tank on c.g.? also, more precise tuning??
just curious thanks again and you operate a very informative forum!!!! |
