OS 40 Max Muffler
Lost the tail cone on a O/S 40 Max Muffler in flight.
What a great engine - what are my options on for replacing it. Any third party mufflers that would easily fit? |
RE: OS 40 Max Muffler
ORIGINAL: wtsidney Lost the tail cone on a O/S 40 Max Muffler in flight. What a great engine - what are my options on for replacing it. Any third party mufflers that would easily fit? Was the screw still on the muffler after you were able to land? roltech |
wt, if your engine is a .40FP, here is the Tower Hobbies offering: http://www2.towerhobbies.com/cgi-bin...=++&search3=Go
The tail cone is the same as the one on the 46FX and the 40/46LA so you should be able to get your LHS to order the part for you. There's lots of those series of engines out there, maybe someone has a spare muffler you can get the part off of...
There are a number of after-market mufflers you can use. You'd find better response in the General Glow engines forum. The replacement O.S. muffler should also be available.
Thanks - Just noticed the part number on the muffler #743 and found replacement parts
| All times are GMT -8. The time now is 01:03 PM. |
