RCU Forums
-   O.S. Engines Support (https://www.rcuniverse.com/forum/o-s-engines-support-133/)
-   -   OS .30 Fuel (https://www.rcuniverse.com/forum/o-s-engines-support-133/3970193-os-30-fuel.html)
chowderhead72 02-27-2006 11:35 PM
OS .30 Fuel
I am currently running an [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXLGH7&P=ML]OS .30 VG(P)[/link] with [link=http://www.teamtrinity.com/shop/nitronec/fuel.html]Trinity Nitro Power Platinum 30%[/link] with an [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXCB29&P=ML]OS A5 plug [/link]with ambient temps in the 30-50 degree range. I have about a half gallon through the engine with great compression/pinch. The problem I am having is that the engine is running so rich the oil drools out of the pipe yet it still has a mid range cackle suggesting a lean condition. Any suggestions? I have also purchaced a gallon of [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXBGG9&P=ML]O'Donnells 30%[/link] in hopes of correcting the problem but I have not opened the fuel yet in hopes of you may have a suggestion. Is my compression to high? Glow plug too hot? Fuel just all wrong? I have checked for air leaks and come up with nothing other than a loose carb(fixed) and a compromised fuel line (fixed) but the problem persists. Please advise.
Bax 02-28-2006 11:26 AM
RE: OS .30 Fuel
If the engine is running too "rich", then the high-speed needle's not set correctly. Even when it's set correctly, you will get oil coming out of the pipe. After all, the oil doesn't burn, and some will collect in the exhaust system and drip out. This will be especially noticed after you shut the engine down. It's a common thing to get oil dripping from the exhaust outlet. That's wny people have been stuffing a bit of paper towel or rag in the outlet at the end of the day....to absorb the residue that drips out.
For proper tuning, you have to get the full-throttle mixture set first, then the idle. Midrange is controlled mostly by the idle mixture setting. You want the engine's idle speed to be just slow enough that you can sit the car down, apply the brake, and the engine's RPM will not sag. It's normal for the car to "ooze" off when you release the brake at idle. The clutch shoes will still tend to wipe the clutch bell and move the car. The engine should not be turning high-enough RPM that the clutch is actually trying to engage...that's what can cause the engine to slow down when you apply the brake.
