RCU Forums
-   O.S. Engines Support (https://www.rcuniverse.com/forum/o-s-engines-support-133/)
-   -   piston ring (https://www.rcuniverse.com/forum/o-s-engines-support-133/4487400-piston-ring.html)
maayan 07-11-2006 04:04 AM
piston ring
hey,
how can i know if there's a need to replace a pistion ring on my FS91II?
thanks!
Bax 07-11-2006 11:50 AM
RE: piston ring
If your engine has poor compression, then either the valves are not properly-sealing, or the ring is not sealing. You can tell the engine has poor compression either by a low compression feel when you turn it over, or by a poor or non-existent idle after the engine's had a lot of successful running with a good idle.
maayan 07-11-2006 03:01 PM
RE: piston ring
thanks!
* i would like to mention that the engine has great compression.
keeps steady idle. and turns good rpm.
and if i may, i have another question:
a couple of months ago i posted about my 91FSII-P.
the problem was that even with the needle fully closed- the engine still turns.
as i was advised i replaced the carb body with a new one, but still the same problem.
* the needle itself was also replaced.
i must say the engine does work smoother..
is it normal for a pumped engine?
thanks again
