RCU Forums
-   O.S. Engines Support (https://www.rcuniverse.com/forum/o-s-engines-support-133/)
-   -   Piston ring for os max-h 60 (https://www.rcuniverse.com/forum/o-s-engines-support-133/6564912-piston-ring-os-max-h-60-a.html)
Akozar 10-31-2007 07:50 PM
After 20 years rc absence :( i just got me an old OS Max-H 60. A little knick in the exhaust holes in the liner scratched piston and piston ring.
Liner and piston seam to be fixable but i need a new piston ring.
Does the OS piston ring 60-61 -LXCT 22- from Tower Hobby fit?
Somebody told me the OS piston ring fs 61 -LXCT 21- should fit
Bax 11-01-2007 10:27 AM
RE: Piston ring for os max-h 60
The part:
OSMG7796 26703404 PISTON RING 60-61 US$22.99
Was for the O.S. Max .61FSR. It would not fit your H-60.
This part:
OSMG7792 26603400 PISTON RING FS61 US$22.99
has the SAME parta number as the ring in your H-60, and is the correct part. It was later also used in the FS-61, and was re-labeled after the H-60 was discontinued.
Akozar 11-01-2007 07:08 PM
Thank's a lot Bax [8D]
As soon i got liner and pison smoothened i will try to get the engine working again
Andy
