RCU Forums
-   O.S. Engines Support (https://www.rcuniverse.com/forum/o-s-engines-support-133/)
-   -   OS 91 Surpass header (https://www.rcuniverse.com/forum/o-s-engines-support-133/7271198-os-91-surpass-header.html)
rcbobp 03-23-2008 06:09 PM
I have a new 91 Surpass (non-pumped). After running a tank through, I have 5 flights and have now gone through my 3rd header (pipe between engine and muffler). Each one has cracked right on the threads in the muffler. This latest time i checked and double checked that the lock nut was tight (but not too tight) and there was no vibration when I took off. Any suggestions? I can't believe it's so sensitive to movement. No other engine has had this problem.
thanks.
Bob P
errie 03-23-2008 06:25 PM
RE: OS 91 Surpass header
Strange, really Strange!!! Is your prop balanced? maybe some extra vibration could cause this
rcbobp 03-24-2008 04:39 AM
Yup, balanced, then rebalanced just to be sure. Another guy at our field had the same problem with the same engine in his RV-4.
Bax 03-24-2008 11:07 AM
There just has to be some vibration that's causing the heavy muffler/manifold assembly to move a bit. That will cause stress right at the engine. You'll need to support the muffler to prevent this from happening. With this large an engine, it's easy to have the manifold stressed. While you may not see much vibration, it's there, and it's causing the muffler to move around.
