from 10% nitro to 15%, break in again?
The manual is a bit vague on this.
I have two engines: .46 FX and .91 Surpass II. Same question for both. Thanks, Shane |
Shane,
Changing between 10% nitro fuel and 15% won't hurt a thing. It's done all the time. As long as the engine doesn't go too lean, you'll be fine. Just remember that the needle does change when you change fuels. |
Thanks Bax.
Originally posted by Bax Shane, Changing between 10% nitro fuel and 15% won't hurt a thing. It's done all the time. As long as the engine doesn't go too lean, you'll be fine. Just remember that the needle does change when you change fuels. I have a .46 FX and a .91 Surpass II Both newly broken in with Omega 10% I would like to run both engines with the same fuel. -probably Omega 15% and stick with that for good. But I noticed that Morgan fuel also sells a "4 stroke" fuel. Thoughts? |
