RCU Forums
-   O.S. Engines Support (https://www.rcuniverse.com/forum/o-s-engines-support-133/)
-   -   OS18TM problem (https://www.rcuniverse.com/forum/o-s-engines-support-133/7598710-os18tm-problem.html)
sgtcat 06-09-2008 12:40 PM
OS18TM problem
Hi i have a Os 18 TM installed in a lightning gt10 and i can't find the factory settings.i bought it used and the guy didn't tune it.
Bax 06-10-2008 09:19 AM
RE: OS18TM problem
The initial "ball park" settings are in the manual. You can get one here:
http://www.osengines.com/manuals/index.html
oslover 06-22-2008 04:32 AM
RE: OS18TM problem
hi
ok the high speed is 4 full turns out for a good len/rich run . the Metering Needle has 4 full turns out, Mixture Control Valve 2 full turns and half out. hope thats helps :D
