RCU Forums
-   O.S. Engines Support (https://www.rcuniverse.com/forum/o-s-engines-support-133/)
-   -   Carb secure screw question (https://www.rcuniverse.com/forum/o-s-engines-support-133/8201838-carb-secure-screw-question.html)
Randy K 12-01-2008 03:03 PM
I am replacing the carb on my 40 LA engine. When I re-install it, should I use loctite(or something else) on the two hold down screws that secure the carb to the engine?
Bax 12-02-2008 10:14 AM
RE: Carb secure screw question
If the screws are firmly-tightened, you don't need thread-locking compound. If you do use it, though, don't use the permanent kind.
