RCU Forums
-   O.S. Engines Support (https://www.rcuniverse.com/forum/o-s-engines-support-133/)
-   -   Another OS140FI question (https://www.rcuniverse.com/forum/o-s-engines-support-133/900807-another-os140fi-question.html)
MarkNovack 06-26-2003 05:49 PM
It turns out that I did need a new rear bearing. I found a good German bearing of exact specs, although I took the seals off of it. I was surprised that the OEM was a sealed bearing. Anyway, big difference now. All of the RPMs are back.
Here is another situation. On dissasembling the motor, when I removed the airvalve, the little plastic insulator stayed in the crankcase. I pulled it out, but I noticed that there was some sort of adhesive that originally held it to the air valve. I got a nice tight fit when replacing everything, but I had to tighten the airvalve retaining screw more than normal to keep the airvalve from turning. What kind of adhesive can I use to reglue the insulator to the airvalve stem, or do you think that as long as it does not turn I'll be OK?
Also, is it possible to get a replacement insulator without buying a whole air valve. I do not see that individual part listed a Tower, and the airvalve itself is very expensive ($375.00).
Thanks for your assistance. I know that these motors do not bring the easiest answers.
Mark
Bax 06-27-2003 01:21 PM
Mark,
The plastic insulator comes only with the air valve body or the complete assembly. It's not available as a separate part. You'll have to contact your O.S. Max distributor for prices and availability.
