Subwoofers, Amplifiers...
ON, CANADA
RE: Subwoofers, Amplifiers...
Ah, I see a problem with your humour.
-20' or 240" is 6100mm which is is about 3 times wider then your average car width.
-Your average v6 engine produces about 160Kw, a bit lower than 2500Kw.
- Most aftermarket decks produce about 15-20w per channel. That is 0.08Kw. A bit lower than 300Kw through the wheel.
Ryan
Ryan
i had a atmomic audio ap/spl 12, custom box. 4 cubes, ported, planet audio p2250d class d mono, optima yellow top, 140a alternator, 2 runs 0 ga to amp power and ground, cdt upstage kit, mid woofers, dei crossovers, sony head unit.
sub was so loud it flexed my steering wheel. [X(]
"-20' or 240" is 6100mm which is is about 3 times wider then your average car width.
Ryan"
Um yes, Ryan...that was the point. OK so 20' should have been 20" but what the hey...?"
Have another read. I'm not sure you read it right first time, see...
Ryan"
if i got an suv id do another system. but would need a suv to do what i want to do. would do 2 x 12" atomic ap/spl subs, 2 sundown saz 1500d amps, 250a alternator and 2 yellow tops. should rock the house
