Off Topic Forum - Cars, Trucks, Buggies and more Get to know your fellow RCU member modelers in here and discuss off topic non-rc stuff. Only two topics OFF LIMITS are religion and politics. This forum for car & truck members. Plane & Heli members have their own in clubhouse section.
Speaker Issues
Old 02-05-2011, 05:22 PM
DarkFire989
DarkFire989's Avatar
Default Speaker Issues
My Roommate has a Cambridge Soundworks MicroWorks system from 1999. The other day the fuse blew, so we replaced it, no problem. Now.... When we turn it on it works A-ok for about 5 seconds, then the sub slowly dies out while the speakers keep going. Its a 2.1 system. Any suggestions? Thanks.
Old 02-05-2011, 05:50 PM
The Hedgehog
The Hedgehog's Avatar
Default RE: Speaker Issues
Is this hooked up to an amp? Can you try plugging in other speakers to see if it does the same thing?
Old 02-05-2011, 05:55 PM
DarkFire989
Goes from a laptop into a pre amp, then into the sub woofer, which the speakers are connected to. There are no other speakers on hand to test. We have been using this set up all year with no problems. After the fuse blew its been a problem ever since.
Old 02-05-2011, 06:02 PM
The Hedgehog
Hard to say then if you can't narrow down some of the possibilities.
Old 02-05-2011, 06:08 PM
DaveG55
DaveG55's Avatar
Kinda sounds like the amp powering the sub has took a dump on you.
But w/o some checking / swapping some speakers in to see if the problem stays the same it's hard to say
Old 02-05-2011, 06:10 PM
DarkFire989
Its a self powered sub. We just run it through a receiver, sorry not a pre amp. Its probably the power supply in the sub thats going.
Old 02-05-2011, 06:33 PM
splcrazy
the fuse blowing is telling you there is a problem , my guess is the amp itself is dying and is now drawing way too much current power . i had the same thing happen in my car amps
