Great stuff for making protective barriers and leveling out the ground for scale buildings.
MI
This can be used for making barriers for tanks and it has some other uses, but I didn't think that it belonged in the tank forum. Hey I did this for an upcoming review. It is a mud type base. All you need is soil and water. Put some gloves on if you need to. First put some soil in a bucket. Then use put water in and cover all the soil. Thirdly sift out all the roots and junk from the top of the water to the bottom of the sand. Then mix the water and mud, let it sit for 5 seconds and pour out all of the water. Then put a little bit of water mix and when the soil looks like it is a watery solution it is ready to pour. Note keep mixing as it will set up quickly at least on a hot day. Pour all of the solution into a mold or form or just pour and shape as it sets up. When it dries out you have a nice solid foundation or what ever you poured it for. So what do you guys think?
