Off Topic Forum - Cars, Trucks, Buggies and more Get to know your fellow RCU member modelers in here and discuss off topic non-rc stuff. Only two topics OFF LIMITS are religion and politics. This forum for car & truck members. Plane & Heli members have their own in clubhouse section.
My soldering irons tip became flat
Old 06-06-2009, 06:58 PM
500 lb. koolaid man
500 lb. koolaid man's Avatar
Default My soldering irons tip became flat
The tip of my Weller 25W soldering iron was a cone shape when I bought it. And after lots of use, it's 100% flat. How? And last but not least, is this common or strange? Thanks.
Old 06-06-2009, 08:49 PM
HJJFFFAA
HJJFFFAA's Avatar
Default RE: My soldering irons tip became flat
LOLcool.
Old 06-06-2009, 09:05 PM
annie_himself
annie_himself's Avatar
Wow. Thats mad.
Old 06-06-2009, 09:15 PM
DaveG55
DaveG55's Avatar
Um, it's normal for the tips of soldering irons to change to some degree with use. After all they are subject to a lot of heat and a pretty harsh environment. But to become flat... you must have been using it for a long time or putting a lot of pressure on it when it's hot.
Tips are cheap, just get a new on if you like the cone shape. Personally, I prefer a flat (wedge) shaped tip better.
Old 06-06-2009, 09:55 PM
500 lb. koolaid man
HJJFFFAA and annie_himself, no offense but I don't see any reason for the sarcasm. I wondered how slodering iron tips can become flat. I understand that it's not very important. But I was curious.
DaveG55, thanks. Strange thing is I don't recall ever using it for a long time or putting a lot of pressure on it when it's hot, it just slowly decintigrated. I thought it was just a low quality tip or something. Anyways, I'll try and find replacement tips.
Old 06-06-2009, 10:10 PM
Mr. Mugen
Mr. Mugen's Avatar
I'd say strange then. I have been soldering for years and never had a cone shaped tip go flat and I do apply quite a bit of pressure sometimes. I have had tips go bad from use but never change shape. Just my exp.
Kevin
Old 06-06-2009, 10:15 PM
DaveG55
DaveG55's Avatar
I've had the points deteriorate so much that they were nearly flat. Not flat like a wedge or chisel but more like flat like an unsharpened pencil. But those were really old tips.
Old 06-06-2009, 10:27 PM
HJJFFFAA
HJJFFFAA's Avatar
ORIGINAL: 500 lb. koolaid man
It wasn't sarcasm. I thought it was cool.
Old 06-06-2009, 11:05 PM
500 lb. koolaid man
HJJFFFAA sorry for the misinterpretation
Looking even closer at the completely flat tip, it cones inward. The tip isn't really old, neither is the gun, maybe 2 years old.
Old 06-06-2009, 11:50 PM
guver
My Feedback: (325)
All mine do it eventually, but they were probably LONG overdue for replacement before they started getting smaller.
Old 06-07-2009, 08:04 PM
madmax22
madmax22's Avatar
got any pics? I'm curious to see it.
Old 06-07-2009, 09:13 PM
500 lb. koolaid man
Here ya go...
Old 06-07-2009, 10:55 PM
guver
My Feedback: (325)
Your tip is conmpletely gone, lol.
Old 06-08-2009, 02:00 AM
500 lb. koolaid man
ORIGINAL: guver
Thanks, I couldn't tell
Old 06-08-2009, 08:45 AM
Eman77
Eman77's Avatar
I've had my iron tips (that start out wedge shaped) eventually disintegrate, starting with almost getting a hole in them.  It's happened twice, I just get new tips then.  It's a hobbico 25 or 30W, I think.  In my case, I just figured they were cheap tips and just "wore out".
Or maybe I should stop heating them up to full temperature and smashing them with bricks.  One or the other.
(joke, joke!)
Old 06-10-2009, 10:26 PM
madmax22
madmax22's Avatar
thats pretty crazy! I had a wedge one get a hole in the middle of it, but I drinded it down till it was back to normal with a dremel, but that is crazy!
Old 06-11-2009, 11:10 AM
The_Collector
The_Collector's Avatar
Normal for that to happen. You can grind them in a pinch, like madmax suggested.
Old 06-11-2009, 04:53 PM
500 lb. koolaid man
The tip started to look just like a 22 hollowpoint while grinding
finished, turned out pretty good
Old 06-11-2009, 05:26 PM
madmax22
madmax22's Avatar
looks good to me!
