Off Topic Forum - Cars, Trucks, Buggies and more Get to know your fellow RCU member modelers in here and discuss off topic non-rc stuff. Only two topics OFF LIMITS are religion and politics. This forum for car & truck members. Plane & Heli members have their own in clubhouse section.
Python's Tech Tips Pc Build! Update
Old 06-11-2009, 09:07 AM
pythonfan
pythonfan's Avatar
Default Python's Tech Tips Pc Build! Update
ok guys this is in relation to my other thread located here ( [link=http://www.rcuniverse.com/forum/m_8829776/tm.htm]Click Me[/link] )
This will be my build thread, pictures, videos, reviews the whole 9 nine yards, also of course the benchmarks and etc...
EDIT: the Tech Tips is for one of my gaming sites i'm doing a tech series.
If there is anything you would like to see as i build my new system or cretin benchmark go ahead and ask and i'll see what i can do.
So i got my first parts in the mail the other day and here are the pics and video.
Pioneer Black Combo drive
Link Depot 3 Pin Fan Power Y Cable
His Stalker clear sky
Video unboxing - HD - Sorry i have a small cold.
[youtube]http://www.youtube.com/watch?v=kNQoscOcSZ4[/youtube]
Old 06-11-2009, 12:29 PM
Clymer122693
Default RE: Python's Tech Tips Pc Build! Update
Joe, no looking up dirty stuff now
Old 06-11-2009, 11:14 PM
pythonfan
pythonfan's Avatar
Ok here;s some pics of the build, i'm on it right now gotta get my video edting softwear on here then you will have the videos.
Old 06-11-2009, 11:19 PM
pythonfan
pythonfan's Avatar
The Blue Glow!!!!!!!
Old 06-11-2009, 11:42 PM
ryansiki
RADIOACTIVE!!!!
Old 06-12-2009, 05:52 AM
snowbl!nd
snowbl!nd's Avatar
Lookin' good. Just one thing - tidy those cables!
Old 06-13-2009, 10:07 AM
pythonfan
pythonfan's Avatar
New Video - Watch in HD
[youtube]http://www.youtube.com/watch?v=vKfYDGOtduc[/youtube]
Old 06-13-2009, 11:39 PM
boltech
boltech's Avatar
Python.. You may want to check to see if your running in dual channel mode. download and run CPUZ (http://www.cpuid.com/cpuz.php)
That second DIMM may need to be moved to slot 3 (inner orange slot) to get dual channel mode. Motherboards can be misleading with the color scheme of the slots sometimes.
Old 06-14-2009, 04:09 AM
pythonfan
pythonfan's Avatar
well in the book it said to put them in the same, i was use to one in yellow and one in orange but i did what the book said here hold on.
Note these are stock speeds, the cpu is a bit warm cause i just came out of a game and saw you wanted these SS.
Old 06-14-2009, 10:57 AM
DarkFire989
DarkFire989's Avatar
That RAM is incredibly slow
Old 06-14-2009, 05:21 PM
boltech
boltech's Avatar
Ok Looks like u got dual channel then. The 'unganged' does draw some curiousity. Try flipping the second dimm to the inner orange slot and see what CPUZ reads.
I find motherboards where the slot colors are grouped together a bit misleading. I've come across systems where I populated ram by slot color only to have single channel mode. once I moved the inner module over 1 into the different color slot I got dual channel mode.
Old 06-14-2009, 05:27 PM
boltech
boltech's Avatar
Other manufacturers Alternate slot colors so by populating ram by color you get dual channel mode. example
Old 06-15-2009, 08:15 AM
boltech
boltech's Avatar
Did a bit if reading last night.. for Phenom II it can go either way. Your technically in single channel mode right now but that is where you probably want to be. It depends on the type of apps you run. Best bet take gaming benchmarks, switch to ganged mode and run the benchmarks again and see which is better for you. Post the results as I'm interested to see what the results are.
Phenom has two memory controllers on the CPU.
Ganged is setting both memory controllers to work together which allows data (that is being used by all cores) to await on the queue until they are accessed.
Unganged means that the two controllers work independently. This allows them to work asynchronously with reference to individual clocks with their one or two Dimms.
Old 06-15-2009, 09:59 AM
pythonfan
pythonfan's Avatar
sure thing bolt, is pc mark, futuremark etc ok?
Old 06-16-2009, 01:14 AM
boltech
boltech's Avatar
yup!
Old 06-16-2009, 01:27 AM
pythonfan
pythonfan's Avatar
i got 2 of the 8 done, doing 4 with the ram as is all there tests, then going to do them again with the ram moved, cpu and gpu are stock clocks nothing is overclocked.
Old 06-16-2009, 07:51 AM
pythonfan
pythonfan's Avatar
ok the tests are all most done, i will post results with the ram as is which is 1-2 and then with the ram as 1-3.
Old 06-16-2009, 08:53 AM
pythonfan
pythonfan's Avatar
ok bad news, i could not run all the tests, i need to buy the program and i don't really have the cash right now so i'll give you what i got.
i will have the results in this format:
Higher is better.
Ram 1-2 (100)
Ram 1-3 (99)
Difference (1)
__________________________________________
3DMark 06
My System Ram 1-2 (13206)
http://i241.photobucket.com/albums/f...ark06ram12.png
My System Ram 1-2 (13176)
http://i241.photobucket.com/albums/f...ark06ram13.png
Difference (30)
3D Mark Vantage
My System Ram 1-2 (P7592)
http://i241.photobucket.com/albums/f...kvantage12.png
3d Mark Vantage
My System Ram 1-3 (p7570)
http://i241.photobucket.com/albums/f...ntageram13.png
Difference (22)
Pc Mark 05
My System Ram 1-2 (9620)
http://i241.photobucket.com/albums/f...cmarkram12.png
My System Ram 1-3 (10159)
http://i241.photobucket.com/albums/f...cmarkram13.png
Difference (539)
Pc Mark Vantage x32
My System Ram 1-2 (5606)
http://i241.photobucket.com/albums/f...ntageram12.png
Pc Mark Vantage x64
My System Ram 1-2 (6055)
http://i241.photobucket.com/albums/f...gex64ram12.png
Old 06-16-2009, 12:39 PM
pythonfan
pythonfan's Avatar
Case Unboxxing - Watch in HD
[youtube]http://www.youtube.com/watch?v=6eehHfpX7dQ[/youtube]
Old 06-16-2009, 11:59 PM
boltech
boltech's Avatar
wow that is surprising that it would make such little difference, I was hoping to see a larger gap of maybe 5 - 10 %
Thanks for posting the results!
