Vintage Craftsman power reel lawn mower
WA
My dad recently picked up a (free) Craftsman lawnmower with the intention of donating the engine to my schools auto shop. But it started one the FIRST pull. So after draining the fuel, putting in new fuel and adjusting the low end screw slightly, it idles pretty good. I thought I would try to make it into a go-kart. My dad thinks, since it's a reel-type mower, that I could just use a cutting torch to cut off the blades, take off the handle and there's the whole rear end of the go-kart. I thought it would be better to build a frame and bolt the engine in. His way would definitely be easier, but there's a v-belt coming off the engine, then a small chain, then ring and pinion gears in the wheels. Seems like a lot to go wrong. But really, my main questions is, should I make it into a go-kart or do a restoration of the mower? I'll probably just make a go-kart if the mower wouldn't be worth anything. I have some info on the mower, like engine and mower model numbers, engine serial.. I found the blown-up parts view on Sears website, but it doesn't really have any information on it. Here everything that I wrote down from on the mower.
Engine: 3.0 HP with Super Start pull starter, model number is 143-5731052 and the serial is 7151-08273.
Mower: Serial number is 536-8198-7, it's a CRAFTSMAN 18 inch craftsman reel power mower (copy and paste from Sears website). There's a little steel piece by the blade underneath that has the number 25317 (I don't know what that number is for). On the mower plate that has the serial number and model number is says "Sears Roebuck and Co. USA" and below that it says "Simpsons - Sears - Limited - Canada"
That's pretty much all the info I have on it.
[link=http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=53681987&pathTaken=partSearch]Link[/link] to the mower parts and a [link=http://www.searspartsdirect.com/partsdirect//partsdirect/getModel!retrieveModelDetails.pd?modelNumber=14357 1052&productCategoryId=1503500&brandId=0247&blt=11]link[/link] to the engine parts.
ON, CANADA
RE: Vintage Craftsman power reel lawn mower
3.0 hp isnt much for a go-kart. Build a death cart: http://hackaday.com/2010/03/20/tim-t...de/#more-22578
You can get a centrifugal clutch like that at any tractor supply store.
Location: San Diego but living in Dubai, UNITED ARAB EMIRATE
Rebuild the mower and in your spare time and weekends, go around the neighborhood asking people if they want their lawn mowed. Build up a steady base of repeat customers. I used to do this with an old fashioned push mower that I towed behind my bike. Take the money you make, save it up and either buy a nice used go-kart or more RC stuff...
ORIGINAL: tommygun32
i actually saved up $1600 and got my first car with that!
