I would like to dispel a myth here.
#152
RE: I would like to dispel a myth here.
[b]A new world wasn't needed. The posts about mixture should have stayed in engines, and all the power/pitch posts to aerodynamics. Aerodynamics that is, for all but the fellow who "Doesn't get it." His should go in the beginner's forum.
JMO.
Bill.
JMO.
Bill.
#154
NJ
So does anyone have anything to say?
I then went on a search for the answers and right here on RCU I was told '' all the control services do is point the plane in a particular direction and the thrust is what keeps it in the air.
Perfect example : I use to love making paper planes. I made one for my nephew one day and when I threw it it stay in the air for a good 2 seconds. Then I added to small elevators pitched up about 30 degrees and when I threw it ( I was in the house ) it never landed it actually went from the dinning room to the living room and hit the wall . I can't explain it any clearer than the elevator pitched the nose up and gave it a longer flight but the plane never went higher or lower when thrown at the same velocity.
RCF esq.
#160
CA
Since this is the off topic forum I have a question for Jettpilot. This is nothing more than a question so no one take it any other way.
Are you a Jet pilot as your moniker indicates? Just curious.
#161
RTK:
I always assumed, with the double "T" that he was flying one of Dubby Jett's engines.
Now you.
Real Tender Kid ?
Rotten Tomcat Kicker ?
Raunchy Turkey Killer[b] ?
What?
Haw.
Bill.
Now you.
Real Tender Kid ?
What?
Haw.
Bill.
#163
I tried to work out how much the castor cools the engine, but gave up when it turned out looking like work.
#165
[b]
Familial Longings, Yearning (for) Children Featuring Incredible Intelligence.
Not all that great, but on the spur of the moment...
Bill.
Bill.
#167
Rotten Tomato Kicker[b]:
(New one just for you.)
Familial Longings, - wanting to raise a family
Yearning (for) Children Featuring Incredible Intelligence. - with all his kids very smart.
Bill.
EDIT> Sorry, that's the reverse acronym of "Flycfii." wr.
Bill.
#170
My Feedback: (15)
I had to go back to my 121 and 131 days...but I think you guys have some good accurate info here...but it seems to me on an aproach to landing ILS or VFR the throttle was used keep us in the air and the steering wheel guided the ship...4000+hrs and never lost a single sole... but then again the throttle can be managed to stay on GS with a fixed pitch...
but then again that was a long time ago...and since then I have hit my noggin a few too many times..[sm=bananahead.gif]
Set RTO Power, Power Set, airspeed alive, cross checked 70 kts, v1 rotate, positive rate gear up, gear lights out, ding ding, flaps 5, flaps up, Yellow bug Yaw dampner on, auto pilot on...now gimme my magazine....
#171
My Feedback: (29)
I have never noticed a mixture change with altitude or airspeed. All my non pumped engines experience a very noticeable mixture change as the tank empties, so I set the needle a little too rich on the ground and after a couple of minutes in the air its perfect.
