RC fuel system
1 Attachment(s)
Hi, hope this is the correct place for posting
a very general question about rc fueling. I do not have an rc engine, but I would like to use some of the parts to set up a power jet on a 50cc 2 stroke, Yamaha Vino scooter. Right now I have mounted an adjustable high speed jet from Traxxas, and would like to set up a separate fueling system for it. Initially it would be for delivering a higher oil percentage mixture at full throttle, but eventually I would also like to experiment with different fuels. Trying to keep it simple, I notice that rc carbs, mounted right on the engine, don't use float bowls. Was wondering what the mechanism is that keeps fuel delivery correct anyway.... and apply that to my setup, if possible. Seeing that I only need to supply fuel under one condition, is just a gravity feed to the jet acceptable? I posted here since you guys must have good fuel delivery even upside down, so are probably more expert on making sure everything works under all conditions. many thanks Walter |
RE: RC fuel system
1 Attachment(s)
Hi again... did some homework and came up
with this. Seems like the regulators need at least a couple of pounds pressure. Would anyone know if the Perry pump can do that? |
| All times are GMT -8. The time now is 08:33 AM. |
