Brushless engine help
I have bought and E-sky king3 witch the brushless engine burned on on the third time i used it.
I have now recived a new engine and ESC from the Hong Kong dealer but when i connect this the engine is not spinning but its "jumping". If i lay the engine on a table and try to throttle it up it wil just hopp around on the table. Since this is how the first engine acted when it got bured i dont want to push the testing to far atm. I dont know what could be wrong. Any tips? All the wires are correctly connected and the buttons and trim on the transmitter is where the manual says it should be. Could it be a faulty reciver or transmitter unit? |
RE: Brushless engine help
Hi,
If you have received a new ESC and a new engine, you have to set up the ESC. It seems to me that the timing isn't correct. Cheers |
Engines run on Internal cumbustion....MOTORS run on electricity.
| All times are GMT -8. The time now is 05:02 PM. |
