OMP - Ohio Model Products Support Forum Discuss products and get support from OMP. This forum is operated by the owners of OMP and your support questions or complaints will be handled as OMP deems appropriate.
48'' Katana - Tank under wing?
Old 04-25-2005, 11:21 PM
papadale
Default 48'' Katana - Tank under wing?
I would like to mount a larger tank on my Katana under the wing, My YS 63 should pull the fuel ok but I'm not sure if its a doable thing. Any comments or suggestions will be appreciated.
Dale
Old 04-26-2005, 05:32 AM
majortom-RCU
My Feedback: (40)
Default RE: 48'' Katana - Tank under wing?
My comment is it's probably do-able, but I'm not sure it would be desirable. Unless your field is littered with balsa magnets, a deadstick with this plane is no disaster. Some days half my flights end in deadsticks because the plane is too much fun to bring down as long as there's fuel in the tank. I would think with your YS63 and typical 3D flying you'd get 15 minutes out of the stock tank. Tank under the wing would be draggier and complicate the lift characteristics I would think.
A better solution in my mind would be higher nitro. If you buy your fuel by the case, 30% nitro is not much more expensive but it is more economical. I find on my YS63 with 30% vs 20% I use less throttle so I get a few more minutes per tankful--I once calculated about 30% more flight time.
Old 04-26-2005, 06:57 AM
AFSalmon
AFSalmon's Avatar
I really don't see the need to mess with a good thing if you know what I mean. The standad side mounted tank arrangement is well proven and reliable. I can get well up to 12 min of flying and still have fuel left. Flying 3d profiles usually means you are only averaging half throttle most of the time anyway.
Old 04-26-2005, 10:07 AM
Thunderhead
Thunderhead's Avatar
Aint that the TRUTH!!! You can even SEE how much is fuel is left (or lack of) and you still dont wanna come in!!!!
Old 04-26-2005, 08:29 PM
papadale
I appreciate all your comments and I will leave it alone, HE Can Be Taught!
Thanks again
Dale
Old 04-27-2005, 07:46 AM
AFSalmon
AFSalmon's Avatar
Hey, how about fuel bladders in the wings like a real plane? Need a pump but just think, you could fly for hours!
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
