Need help fixing my 67” kit build fusion
AZ
Ok I need help fixing my 67” kit build fusion the foam seems to all right but the sheeting is broken in several places mark by the black wavy line should put epoxy in it with a syringe or some foam safe ca any help is appreciated
Thanks Tom
Thanks Tom
SD
RE: Need help fixing my 67” kit build fusion
Hey Chuckar Looks like your doing fine. One thing I find works well on a break like this where you have put the wavy line, is to take an awl or pick poke holes along entire length of the wavy line squeeze in some Gorilla glue the type that expands wipe off excess, and let set up. After the glue expands and dries sand down. This will help fill any foids in the foam. Hope this helps.
P.S. Been there, done that, got the T shirt would you like to see it LOL!!!!
Good tips Jerry. Be careful though if you get Gorilla glue or any expanding urethane glue back under teh sheeting because it will expand and puff up the sheeting. You can always put some flat boards and weight back on top to prevent that though.
