Control Horns for 47" Yak
Just finishing up this kit and haven't grabbed any control horns for it yet. Do you all recommend any particular brand/size for these 47" profiles?
RE: Control Horns for 47" Yak
Personally I use the Great Planes horns and clevis's. Never had a failure with em yet.
We also use Dubro a lot around here also. Here's a tip for balsa models though: after drilling the screw holes for the horns, wick some thin CA into the holes and surrounding balsa to harden this area up some. Helps prevent the horns from squishing into the wood so much.
