Changing Parkzone Night Vapor to Mode 1
Hi,
I have a Parkzone Night Vapor and it comes as Mode 2. There is a switch on the transmitter to change to Mode 2.
This switch will change the electronics (channel assignments) but it does not change the stick tension from the right stick to the left stick.
When I open up the transmitter, there is no obvious stick spring nor assembly to switch.
Does anyone know how to switch the spring tension on the sticks?
I assume that since there is a switch for the electronics, there must be a way to mechanically switch the spring from the right to the left stick. There is nothing telling you how to do this in the manual.
Thanks in advance.
Fly4Fun,
Wayne
Thanks in advance.
Fly4Fun,
Wayne
