GWS corsair CG question
I have a GWS corsair with the stock 350 motor. I have read that the CG should be set forward of the recommended value. What is the best CG point from the leading edge of the wing for STABLE flight. I just want the best chance of flying the thing around until I get used to it then I may try to change things since I am not that experienced and do not have access to skilled flyers to teach me. I would appreciate any input on this. Thank you.
Abearcat,
I fly mine at 53mm back from leading edge.
No landing gear, no ailerons.
Check your lateral balance as well.
Mine is flying fine although I would do ailerons instead of rudder if I were to do another.
good flying
good flying
Banned
Just follow instructions as far as CG goes. I have 4 GWS planes and they all fly well with reccommended settings. No matter what you put on it stick with what the book says for CG and you will be fine.
WB
WB
NY
I fly mine at 60mm from leading edge. Better a little nose heavy because you can a least control the airplane. Tail heavy can spell disaster because it will fly very eratic.
