Go Back  RCU Forums > Electric Aircraft Universe > Park Flyers & Backyard Flyers
 graupner mini piper..BRUSHLESS.. >
Park Flyers & Backyard Flyers Discuss RC Parkflyers and rc backyard flyers in this forum
Old 02-04-2005, 01:19 PM
Default graupner mini piper..BRUSHLESS..
Im putting a himaxx 2812-1080 d.d. in a mini piper..and gonna use a 8cell nimh pack...should I use the stk 5x4 prop that is used with the stk 300 motor..any prop recoemendations would be greatly appreciated...or any mods in general./.t.y..
Old 02-04-2005, 04:51 PM
Glacier Girl's Avatar
Default RE: graupner mini piper..BRUSHLESS..
Music
Did you try plugging it in to motocalc? I did a quick check,didn't see that motor listed, may have to manually plug in the numbers.
BJ
Old 02-04-2005, 05:35 PM
yeah,,they dont list that motor..so it makes it hard..
Old 02-05-2005, 12:32 AM
Music
It flys so good stock! Why put in a brushless motor?
Old 02-05-2005, 08:44 AM
just bored ..i guess..lol
Old 02-23-2005, 12:28 AM
Music Publisher> My mini piper is powered by Astro 10 brushless motor that swings a 5.5 x 4 Masterscrew prop. I use ESC Phoenix 10 and Thunder Power 2C 1320 mah. By applying full throttle, the current draw is about 6 amps when I plug in my ampmeter. I would say that this powerplant is a good choice for the mini piper. The Astro 10 has more than enough power to keep this little plane in the air. Ground take off is also awsome with the tail wheel mounted in the back. The flight lasts about 22 minutes on a calm day with some throttle management. I think you should also get a decent result by using the Himaxx brushless motor if you choose the right prop and batteries. I suggest that you start with 7 cells or 2C lithium pack instead of 8 cells. In addition, the stock prop should not be used with the himaxx because it is not designed for brushless motor.
Old 02-23-2005, 09:02 PM
what prop you recomeend??..im using the CBP1150 8CELL PACKC NIMH..with a brushless himax 2812-1080..
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
