Park Flyers & Backyard Flyers Discuss RC Parkflyers and rc backyard flyers in this forum
HELP
Old 02-26-2005, 01:47 PM
Default HELP
Hey guys and gals,
I need a little help. I just got my venom 370 racing motor. I removed the pinon gear from my J3 cub. The shaft on the cubs' motor is larger thatn the one on the venom motor, so the shaft spins in the motor. I was also wondering can I splice the wires from the venom motor to the parkzone wires. Both mounts are covered with solder. I bought some loc tite and covered the gear and shaft in hoping iot will solve that problem, Help someone , I am on the ground and can't fly.
Old 02-26-2005, 02:26 PM
Default RE: HELP
hamerhed,
yes the loc-tite will do the trick ( let it setup over night )
you can splice them be sure to solder the splice and use shrink tubing to cover the splice
Old 02-26-2005, 07:37 PM
Rat1's Avatar
Default RE: HELP
If it were me I would do away with the automotive bullet connectors used and use some deans micros or something better then the stock stuff. Do the same for your battery pack and battery charger.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
