stryker f27b
stryker f27b
I have had my stryker for about 2 months and I still can't find out how to do a barrel role. I got close, I did up elevator and turning at the same time and it finished the spin after losing 15 feet of altitude. How would you do a barrel role without losing altitude?
UT
RE: stryker f27b
It is really hard to do it w/o loosing any altitude. What you do is, pull up a bit so that the plane is nose up, and then release the pressure on the elevator, and simply push the stick all the way to the right or left. (left spins faster) this way your plane wont loose as much altitude.
LT-40
LT-40
NC
RE: stryker f27b
Give it a slight down-elevator while the Stryker enters the inverted position (upside-down) to keep the nose up. That will keep it from loosing altitude. It also helps if you keep the speed up.
WA
RE: stryker f27b
ORIGINAL: jmir
If you're hesitant, just make sure you're three mistakes high when practicing full throttle barrel rolls.
