Crooked rotor mast on Gyro Havoc?
NC
I have an Air Hogs Gyro Havoc. Right out of the box it appears to have a crooked mast supporting the rotor. Before I take a heat source to it and try to bend it straight, I thought I'd ask the gurus if this is supposed to be this way or not.
As you can see from the photo, the there's a distinct crook in the rotor support about 1/2" below the rotor.
I'd appreciate any advice I can get!
Thanks.
Thanks.
GA
RE: Crooked rotor mast on Gyro Havoc?
I couldn't imagine any reason for it to be crooked, all I can see is the shaft wobbling and the blades wobbling even worse, this would create one huge vibration in the body not to mention making it totaly uncontrolable
BUt I have never owned one so I could be wrong
