RCU Forums
-   Park Flyers & Backyard Flyers (https://www.rcuniverse.com/forum/park-flyers-backyard-flyers-148/)
-   -   Aerobird.. fixable? (https://www.rcuniverse.com/forum/park-flyers-backyard-flyers-148/1589618-aerobird-fixable.html)
slgilley 03-04-2004 10:53 AM
Aerobird.. fixable?
I purchased an Aerobird (my second) from Ebay as a used plane. I knew that the wing would need to be replaced, and it seems the tail was damaged in shipment. Well, that's cheap to replace as well, so I can handle that.
However, the tube leading from the front fuselage to the tail, and on which the tail sits, is loose. I *really* don't want to put in $50 for a new fuselage. By drilling a hole and using a wire tie mod for that tube, will it be sturdy and stable enough, or do I need a new fuselage? If not, I'm going to need to try to negociate with the seller. (Could I even add some glue around the back outside to add to the rotational stability?)
Sean.
stevennh 03-04-2004 11:02 AM
RE: Aerobird.. fixable?
I drilled a small hole right were the tube goes into the fusulage and put a very small machine screw in there to keep it from rotating. I drilled another hole in the fusulage near where the tube ends and tie wrapped it down through the fusulage. This has worked well for me. I was having problems with the tube moving up and down and rotating. I have been flying this way for quite a while with no problems.
Steve
Airborne 2007 03-04-2004 06:39 PM
After that put some hot glue or epoxy on the end where the boom enter the fuse.
-John
bojangle 03-05-2004 12:45 AM
From what I've read, these little planes "take a licking and keep on ticking". Since this is your second plane of that type, I'm sure you know to re-check the balance after any repair. Epoxy and ties can add weight, but as long as everything is fairly straight it will probably fly many times. Would suggest a test glide first.
