How to set different throws for Elevator and Aileron in an elevon flying wing
I'm struggling to understand how to set up different values for endpoints for elevator and aileron in my Slinger.
The radio (JR x2610) is set up for Elevons and I have left servo on Aileron and Right on Elevator. I went into the servo travel screen for elevator and Aileron to set up the 10mm up and down throws for the elevator but how do I then give it the 13mm up and down throw for the aileron? Any help would be appreciated. |
RE: How to set different throws for Elevator and Aileron in an elevon flying wing
End points should be set for the maximum throw that you want on the servos. Then adjust dual rates for elevator and aileron to the desired settings.
End points changes the servos, dual rates changes the commanded range when moving the sticks. Hagar |
Thanks for the quick response Hagar.... I think I understand now... so if the max throw is 13mm up and 13mm down for aileron, I use that as the overall max travel for elevator and aileron and then in the dual rates I reduce the elevator to whatever is required to bring it back to 10mm up and 10mm down and leave the aileron dual rate alone.
Is that right? or have I still missed the point? |
Yes, you got it!
Hagar |
| All times are GMT -8. The time now is 05:37 AM. |
