Soft mount that uses rectangular rubber blocks
I have a YS .91 powered Viper (from about the end of the retract days of pattern) that has a soft mount/nose ring engine mount. The soft mount uses rectangular rubber blocks located fore and aft of the engine mounting lugs. They are bolted to a plate which is in turn bolted to the engine mounting lugs. These rubber blocks are now mush and need to be replaced. I've slept since installing the mount and I just don't remember who made them.
Does anyone recall the manufacturer or know of a possible replacement? Thanks, Jerel |
Originally Posted by jerzee4
(Post 11850609)
I've got one installed in a Rubin that sounds like what you describe. I'll look and see if I still have any packaging or labels etc.
Rick H. |
MK used to do something similar too.
Do they look like this? http://www.rcuniverse.com/forum/atta...4&d=1375304290 |
I know I used the same from the World Models.
| All times are GMT -8. The time now is 11:37 PM. |
