Thread lock at an affordable price for modlelers to prevent loose screws!
Vibration is your enemy, so keep all you srews lock down until you are ready to remove them.
243 medium strength blue thread lock for general purpose use for the modeler. Suitable for all metal threaded assemblies. Regular retail for a 10 ML bottle is $7.95-Mine only $1.50 each + $3.00 shipping! ( Up to 4 bottles for the same S&H This thread lock secures and seal bolts, nuts and studs to prevent loosening due to vibration from both glow, gas or electric engines . The product works on all metals, including passive substrates such as stainless steel, aluminum and plated surfaces. It is proven to be tolerant of minor contamination due to industrial oils, e.g. motor oils, corrosion prevention oils and cutting fluids. c=Comes with leak proof screw on lid. Your benefits 1 Prevents loosening on vibrating assemblies, e.g.wing bolts, throttle arms, servos and turnbuckles. 2 Works on all metals, including passive substrates (e.g. stainless steel, aluminum, plated surfaces) 3Proven to tolerate minor contamination by industrial oils, e.g. motor oils, corrosion prevention oils and cutting fluids 4 Permits disassembly with hand tools for servicing. I do not ship outside the US or other countries. I no longer take Money Orders but will take personal checks! Send a personal check if you do not have a Pay Pal Account! My mailing address : George Jenkins, 3015 Bucida Drive, Sarasota, Fl. 34232 NOTE, PLEASE READ ALL OF THIS: Please give me your name, mailing address & email to help me keep track of your order by typing in the item you are buying in the "Detail" section along with your mailing address in your Pay Pal purchase. PLEASE DON'T MAKE ME GUESS AS TO WHAT YOU ARE ORDERING, YOU KNOW, BUT I DON'T! Also, please put in your email address. If you PM me for an item, follow up immediately with a Pay Pal payment to make sure your get what you want. I sell on the "First Come-First Serve" Basis. Please note! My account in Pay Pal is under: [email protected] |
