NGH GT25 25cc, only test ran.
This engine is like new, it was only test ran. I bought it for a project I never got around to building. I have an NGH GT17 that I have been flying for four years and has over 300 flights on it and it has ran trouble free. The NGH engines have Walbro carburetors and are easy to tune. I have found that having an onboard tachometer makes tuning gas engines much easier and I am including a Rxcel tach. Everything is still in the original packaging.
Free Shipping. Engine type: Single cylinder, 2-stroke, air-cooled Bore/Stroke: 33.2 x 29 Piston displacement: 25cc Max. power: 2.7HP/11,000rpm Min. idle Rpm: 1600rpm Practical RPM: 1600-11000rpm Ignition: Rcexl CDI with auto advance Spark plug: 1/4 x 32 Rcexl Carburetor: Walbro WT series Lubrication oil: 2 cycle Engine Oil API TC / JASO FD or better specs. (Mobil + M2T) General use fuel: 25:1~30:1 Propeller range: 15x10 ~ 16x10 Weight: 1065g (including ignition and muffler) |
I’ll take it
I tried to send you a private message
so how do I reach you ? |
Hello,
I will send you a private message now. Somehow there was a setting that needed changed to be changed for me to have private messages, not sure how that got changed. If you did not get the PM I sent, please try sending me another PM with your email address. |
