Fiberglass fishing pole for pulling servo wires in wing or Fuse!
Ideal for pulling wires for servos through a wing or fuselage and you can make it as long as you need to due the job up to 11' feet! Each shaft is 12" long. $12.00 + $6.50 S&H These will last you a life time if you don't loan them out to you flying buddies.
These non-conductive fiberglass rods can be screwed together to form longer lengths for running wire through walls, attics, crawl spaces, sub-floors, and suspended ceilings. The running kit includes ten 12 in. fiberglass rods with threaded brass connectors, a 6-1/2 in. flexible acrylic connection that can be set to any angle, a brass hook end for pulling and a brass eye end for pushing. o Sturdy fiberglass construction with brass fittings o Can be extended up to 11 ft. o Plastic storage case to keep all the pieces together! I do not ship outside the US or other countries. I no longer take Money Orders but will take personal checks! Send a personal check if you do not have a Pay Pal Account! My mailing address : George Jenkins, 2012 Old Arbor Court, Sarasota, Fl. 34232 NOTE, PLEASE READ ALL OF THIS: Please give me your name, mailing address & email to help me keep track of your order by typing in the item you are buying in the "Detail" section along with your mailing address in your Pay Pal purchase. |
Yeah can be purchased from Lowes too.
