Skymaster BAE Hawk 100
This is a Skymaster BAE Hawk 100. It's a 1/4.6 scale. It is a proven airframe with no compromise on anything. It has been flying well with a Kingtech K210 with all wing stores on.
It comes with a few Detail for Scale options. The lights and lenses are D4S, powered by a single cell A123 battery. The wing tanks are from SM but the outer pylons and rocket pods are from D4S. It has a complete Jeti system with three receivers. Rex12, R3 and R900. It also has the remote aircraft "on /off" with an additional R3. It runs a 2.4 with a back up 2.4 and a back up 900mhz. It also has telemetry for air pressure on both the brakes/ airbrake and the gear/doors. It has both Rx battery info along with ECU battery info. It also has full Kingtech engine telemetry.... And more stuff All fuel systems are high flow. All airlines are Dream works. Wire is Powerbox. Connectors on the wing are Ashloc. Servos are either JR8711 or 8911, except nose wheel. Batteries are A123- 2 RX, 1 ECU and 1 lights. Other misc stuff include, aluminum SWB arms, upgraded main door cyl, CAT UAT, Kevlar hopper tanks, etc Current new prices if to replicate: Airframe 5500, Turbine 2900, jeti gear 725, gyro 300, lights 250, wing stores 250, pilots $200, servos 800, batteries (4) 210, pneumatics 225, mics -kevlar hopper, UAT, DW airline, ashloc, highflow system, PB wire 575 total - $11,935 plus the work to put it all together Available to you in the following situations: Turn key bind to your Jeti $8400 Minus Jeti and cortex - $7800 Minus Jeti, cortex, turbine $5900 This is a local pick up or meet up transaction.....unless you can establish your own shipping. Scammers, don't waste your time. I am suspicious of everything. Thanks for looking. email [email protected] |
