paco ritter |
03-07-2019 06:08 PM |
Hostetler Cessna 206 120"ws
I did not build this plane, only refurbished it. It is a Hostetler design Cessna 206 Stationair, 120" wing span. I feel like it was a National Balsa full kit build, but no way to know for sure. It has aluminum main gear and someone's brand of oleo strut on the steerable nose wheel. I just finished refurbishing and repainting the entire plane. It has flown only 1 flight since built many years ago. I have a video of the flight and landing, which broke the nose wheel gear down tube. I repaired it when I repainted it all. The plane is 120" wingspan, weighs in at around 45 lbs. It has flaps. I have an 8 channel Futaba receiver with a "Y" on the flaps, all other functions on a single servo, elevator halves each on a servo. It has a 5200 mAh Fromeco Lithium Ion battery and voltage regulator on the receiver. Mixture of servos, all heavy duty high torque. Powered by a G62 with magneto ignition swinging a 22 x 6/10 prop. Airplane is a good 9 out of 10, looks really nice, not a show piece but very nicely done. If you own a Futaba radio and want the receiver and battery included in price, I can do that for extra $$$ and if you own a Futaba that has the ability to transfer data between radios via SD card, I can do that. You would be literally plug and play in a matter of minutes. I have everything programmed and set, all you need to do is a trim flight to check all settings. I would prefer trading for a 50cc or larger Decathlon or Super Chipmunk, (the Hostetler 113" plane would be great) Plane is obviously too large to ship. I am willing to meet to deliver or for a fee can deliver anywhere in the Continental US.
