Park Zone VisionAire 3D Park Flyer - Quique Somenzini Design BNF
1 Attachment(s)
This model just sits and clearing my hangar of those models that I just don't fly.
In pristine condition, like new, never crashed and performs great. Add your Battery and Bind and Fly!Attachment 2271047 No shipping, Local Pickup. PM me if interested. Detailed Information on this model can be found at: http://www.spektrumrc.com/Products/D...ProdId=PKZ6580 ParkZone® VisionAire® park flyer is specifically designed for sport pilots by 3D pioneer Quique Somenzini. Its wings are constructed of hollow Z-Foam(TM) material that has been reinforced with carbon fiber to create structures that are stiffer and lighter than solid foam. This rigid, lightweight airframe is paired with a powerful 10-size, 1250Kv brushless motor that delivers the vertical performance you need for an exhilarating 3D flying experience. What makes the VisionAire model such a great 3D plane for sport pilots is the advanced AS3X® (Artificial Stabilization - 3-aXis) System built into its AR635 receiver. The AS3X System works behind the scenes to counter the effects of wind and turbulence, using 3-axis sensing and flight control software tuned by Quique Somenzini. If you've never flown 3D before, this enhanced stability will give you the confidence you need to try high alpha maneuvers like harriers, hovers, torque rolls and more. You can adjust the amount of stability the AS3X System provides or turn it off completely, but even 3D pros will find flying with it on feels completely natural. There are no delays in control response or limits on the control throws. You'll simply feel like you're flying an expertly-tuned model that goes right where you point it. |
