NEW 60W Co2 Laser Engraver Cutter Engraving Cutting machine 20x28" / + upgrades
This is a new never used Redsail X700 Laser cutter that comes with the following extras :
- industrial coolant chiller - upgraded 70W ( 60W standard ) laser tube with screw lock terminals - extra set of mirrors and lenses - 120 to 240V converter - adjustable Z-axis I purchased this machine around 4 years ago and never used it. The pictures show this has never been ran, and is in completely brand new condition! The cutter is located in Jackson NJ, and would need to be picked up locally. I do not have the ability or time to ship freight currently. I originally intended to for hobby use ( scale model aircraft , etc ) however other hobbies took over my time. than you for looking.. ( i reserve the right to end the auction early if item sells locally , or on ebay) here are machine specs : Model X700 Laser tube Water cooling Co2 sealed glass Control system 32 Bit DSP Drive type Stepper motor Laser Power 50W(60W/100W optional) Working Size (mm) 500 x 700 Adjust Table (mm) 200 Max speed 1000 mm/s Image form Plt, Dxf, Bmp, Ai, Dst Resolution 1000 DPI Repeatability 0.01 mm PC Interface USB 2.0 and USB Disk Power 110~240V/ 50~60Hz Machine dimensions (mm) 1160*870*960 G. W. (Kg) 210 |
PM sent
