GeorgeSells |
10-19-2020 12:47 PM |
Flex Innovation Mamba
- Plug in upper and lower wings with pinned inter-plane struts for easy transport
- Balsa, Ply-wood, construction
- Gigantic control surfaces for extreme 3D performance
- Precise Aerobatics with minimum control coupling
- Super-light Rigid Airframe
- Custom G10 Control Horns for Optimized Throw and Precision
- Painted Fiberglass Wheel Pants and Cowling
- Main Hatch and Auxiliary Forward hatch removable tool-free with one Latch
- Optional Shark Teeth Leading edge for reduction of Wing Rock and enhanced low speed control
- Factory applied trim scheme
- Easy to modify for Electric Motor
ARFSV INCLUDES ALL ARF FEATURES PLUS:
- (7) Brushless Ultra-Torque Digital High Voltage Heavy Surface Servos Installed (FPZDS41611BLHV-H)
- (threaded, installed (FPZA0001)
- (1) Potenza 25 Tooth Aluminum Double Servo Arm. 1.25? radius, red, 4-40 threaded, installed (FPZA0002)
- All possible Hinges and Control horn installed
- Some servo extension cords provided
Power (50-70cc Gas) DA70 Recommendations Shown
- DLI 60cc Twin Cylinder Engine (FPMDA70)
- Exhaust System:
- DA Open Stock Muffler (FPMDA70MUFLR)
- or
- DA 2 to 1 header (45mm Drop) (contact us)
- MTW TD110H rear discharge canister
- Tru-Turn 5 in. Aluminum Spinner P-51 style, Hollow Back Plate (FPMTT5)
- Falcon 24×9 gas. Carbon Fiber Propeller (FPMPFC2409)
- 15mm Engine Standoffs (FPM1124
- Aura 8 Open Stock AFCS (FPZAURA08
- Misc
- Wing Bag Set for Main Wings - Order two sets (FPM357018)
- ISDT D2 Charger (ISDTD2)
- (2) Receiver Batteries )
