Extreme flight 60 inch extra rtf
Up for sale is an excellent condition 60 inch ef extra 300.
Includes airframe with under 20 flights... Never crashed. Gforce 5065 400kv motor hobby wing Skywalker 80a esc Hitec 5245 servos. 2 value hobby 6s 3300mah batteries. Everything new to this plane. I had to carefully cut the firewall back to fit the motor I chose.. All thrust angles are perfect and it's probably stronger than stock. There is a small crack in the back edge of the canopy that was repaired and barely noticed... See pics. Flys awesome, I just don't take it out enough. $250 local pick up in NJ... If you fly frsky, I'll leave in the rx and battery telemetry sensor for no extra charge. |
Is the plane still available? |
Yes
still aveliable.
I'm close by NJ |
Originally Posted by vdg727
(Post 12511020)
still aveliable.
I'm close by NJ |
Ef 60
Thank so much for responding. I will wait for your reply. Good Luck |
(Post 12511020)
still aveliable.
I'm close by NJ Sold |
Ef 60
Thanks so much. |
