RCU Forums
https://www.rcuniverse.com/forum/index.php)
https://www.rcuniverse.com/forum/forumdisplay.php?f=560)
Skookum SK-540
https://www.rcuniverse.com/forum/showthread.php?t=11677108)
cswhiting |
04-06-2020 07:25 AM |
Skookum SK-540
Specs:
- Dimensions: 29mm x 38mm x 13mm (1.125?x 1.5? x 0.5?)
- Weight: 18g (0.63 ounces)
- Dual 3-axis MEMs gyros, giving stability and redundancy
- 32-bit processor
- Anodized and laser etched aluminum case
- Supports many input options: Spektrum/JR remote (satellite) receivers (DSM2 and DSMX), Futaba S-Bus, JR DMSS, JR xBus, UDI, Futaba PPM, Jeti PPM, Graupner SUMD, and traditional receivers.
- Supports use as an 8-channel receiver core when used with Spektrum remote (satellite), Futaba S-Bus, JR DMSS, SUMD, or PPM receivers
- Easy to use Setup Wizards and compatibility with SK 720 setup files
- Works with Digital or Analog swash servos, as well as high voltage servos
- Suitable for 120, 135/140, and 90 degree eCCPM, as well as mCCPM swashplates
- Works with 2,3,4, or 5 blades, with phase trim adjustable to ±90°
- Swash Ring anti-binding algorithm
- Internal swash mixing, for accurate control
- Supports Spektrum radios with either 1024 or 2048 servo steps, and 22ms or 11ms frame rates
- Quadcopter and Hexacopter flight control
- Flight logging is now available for the SK540
