Kavan FK-50 4 cycle glow twin
Kavan FK-50 MKI, 50cc, four cycle, glow, RC engine. Excellent condition, Lightly used with full factory upgrade from MKI to MKIII, upgrade nameplate sticker and factory invoice included. Previous owner stated engine had not been flown since upgrade. Includes engine mount, dual glow harness and factory tool set. Also includes quantity two, very hard to find, matching original engine cylinder heads with "Continental" rocker arm covers to match engine plus an extra set of "Continental" rocker covers. Perfect for creating a scale 4 cylinder Continental engine mounted in a 1/3 scale Cub or similar. Price $950.00 OBO. Buyer pays shipping and Pay Pal fee. Below is information from MECOA website for this high quality collector class engine:
KAVAN 50 cc FOUR CYCLE TWIN Absolutely the finest quality... The Kavan 3 Cubic Inch is one of the most outstanding engines available. Truly superb casting and impeccable German workmanship provide you a true masterpiece. The FK50 is a scale version of the world famous Continental engine that was used in many popular early light aircraft. This alternate firing 4 cycle twin is virtually vibration free and extremely fuel efficient. The FK50 is the only model engine made with a "wet sump" oil system with an internal oil pump. The lowest or no oil content glow fuel can be used resulting in the best possible combustion mixture. Also available in ignition version with a two magnet electronic pick up system for advancing and retarding of spark. This allows an excellent low speed idle and reduces possibility of kick back during starting. KAVAN 50cc Four Cycle Twin Engine see KAVAN engines line drawings & dimensions top view o side view o back view o Carb view o Exploded view Engine o Exploded view Carb o parts list SPECIFICATIONS: GLOW IGNITION Displacement 50ccm / 3cu. in. Maximum RPM 8,800 9,200 Induction System 4 cycle o.h.v Idle RPM 1,600 1,400 Bore 34 mm / 1.34" Horsepower 4.6 4.4 Stroke 28 mm / 1.10" Weight 2,450 gr 2,600 gr Prop Size 20x10 (depending on model) Weight 5.40 lbs 5.73 lbs Fuel Consumption 500 ccm / 16 oz / 20 min Retail Price $6,500.00 $7,500.00 |
PM sent, Sir!
Originally Posted by SPACE COWBOY
(Post 12627202)
PM sent, Sir!
(Post 12627202)
PM sent, Sir!
Kavan
Originally Posted by Perdue1
(Post 12627391)
