1/4 Scale Balsa USA DH4 / Just add RX to fly
OR YOU CAN BUT THIS WITHOUT THE MOTOR > ESC and battery ,take off $550 > cowl is not cut , firewall is in the stock location will fit a gas or glow motor
Balsa USA 1/ 4 Scale DeHavilland DH4 / wings are finished with Silver Oretex , Fuselage is Painted , The Stab and Rudder can be removed on this model . Pull Pull on Rudder and Elevator Model , Has been flown , Will fly over 14 min at 1/4 throttle > Included and installed in model > Electric Scorpion Motor > S11-5525-195 Motor > Talon Castle creations 120 amp HV ESC > All R&D ,Digital servos ( 7 ) LF-20 MG > This Flys on 2 X 5000 Ma Lipo Batterys That come with the Model > CG is Correct > all up weight RTF is 34 lbs > All U need to fly is a RX . All parts are new to this Model > This is a large Model 127 inch WS Cash ONLY Pick Up ONLY at my location. |
